Code for receiving data from Nordic key FOB - SparkFun
RonCzap
I have a Nordic RF transceiver module and a key FOB from SparkFun that I wanted to get working with a PICAXE 20M2.
I had some Basic Stamp code that I worked on a few months ago, so I just had to convert it.
I am attaching the code in case anyone might be interested.
Here is program output showing register values and detected button/count info
Initialized
Register 0 = 00111011
Register 1 = 00000000
Register 2 = 00000011
Register 3 = 00000011
Register 4 = 00000000
Register 5 = 00000010
Register 6 = 00000110
rxAddr P0: 231 231 231 231 231
txAddr: 231 231 231 231 231
 442 Top
 443 Bottom
 445 Left
 446 Right
 447 Center
The key FOB description
This is a nicely packaged key FOB that contains a Nordic nRF24L01+ radio and a ATtiny24 for control. Press any one of 5 buttons and the ATtiny24 will wake up, transmit the buttons being pressed, a 16-bit integer value of the total button presses since last battery replacement, and then return to low-power sleep.
RonCzap
I created another demo program which emulates the Sparkfun 5 button Key FOB.
It continously transmits the button codes and 16 bit sequential counter (as the FOB does).
I am attaching the transmit and receive (tweaked) programs...
ppp556
There is a bug in Transmit.bas.
"CE" should be LOW during transceiver configuration and data reading/writing.
"CE" should be HIGH when transceiver should actually send data via RF.
So this block:
LOW CE
PAUSE 1
HIGH CE
should be:
HIGH CE
PAUSE 1
LOW CE
Thank you for the samples, RonCzap!
