Code for directly connected 7 segment display.
crazynight
feeling happy managed to program up a 7 segment display (CA), I know resistors should be there but thought I would live dangerously as will be moving the project over to CC's with 4026B's in the near future. Is there are driver available for Common Anode displays?
[video=youtube_share;Im6HSjfZ_F8]http://youtu.be/Im6HSjfZ_F8[/video]
Is there any way to tidy up this code, it works but seems long winded.
symbol seg_dp = c.0
symbol sega = c.4
symbol segb = b.2
symbol segc = b.1
symbol segd = c.1
symbol sege = b.5
symbol segf = b.4
symbol segg = b.3
;          a
;        f   b
;          g
;        e   c
;   dp     d
Main:
gosub all_off
gosub num_0
gosub num_1
gosub num_2
gosub num_3
gosub num_4
gosub num_5
gosub num_6
gosub num_7
gosub num_8
gosub num_9
all_off:
high sega
high segb
high segc
high segd
high sege
high segf
high segg
all_on:
low sega
low segb
low segc
low segd
low sege
low segf
low segg
num_1:
high sega
low segb
low segc
high segd
high sege
high segf
high segg
num_2:
low sega
low segb
high segc
low segd
low sege
high segf
low segg
num_3:
low sega
low segb
low segc
low segd
high sege
high segf
low segg
num_4:
high sega
low segb
low segc
high segd
high sege
low segf
low segg
num_5:
low sega
high segb
low segc
low segd
high sege
low segf
low segg
num_6:
low sega
high segb
low segc
low segd
low sege
low segf
low segg
num_7:
low sega
low segb
low segc
high segd
high sege
low segf
high segg
num_8:
low sega
low segb
low segc
low segd
low sege
low segf
low segg
num_9:
low sega
low segb
low segc
low segd
high sege
low segf
low segg
num_0:
low sega
low segb
low segc
low segd
low sege
low segf
high segg
ZOR
This decoder/driver will drive common anode displays SN74LS47N
Follow this link and look for the Truth Table. It shows the combinations for getting relevant display digits.
http://www.doctronics.co.uk/4511.htm#truth_table
When you study what 4 inputs are for each digit the code should fall into place
Also look at Picaxe manual 3, output into 7 segment display.
Study up on the LOOKUP command.
http://www.picaxe.com/BASIC-Commands/Variables/lookup/
You can have one byte for each number/character to be displayed and using pins = command can set all outputs in one step.
If the outputs are not all on one port (B or C) then you will need to use a remapping routine.
Hippy has posted such remapping routine in the past if you care to try a forum search.
If you have no series resistors you may overload the PICAXE outputs causing failure of PICAXE internal circuits.
Please always include some resistor to suit voltage and drive method (continuous/PWM/etc)
crazynight
Yes. As said in the other thread. SAA1064 can do all 4 7 segs at once. lookup tables etc. are all in the threads mentioned.
Marz.
I was looking for other means of driving a display as ultimately I need 4" displays, which all seem to be +12v. the SAA1064 is i2c which is great but will be using i2c for the RTC. I have not had much success with multiple I2C devices as some of commands have to happen at the same time which is why I am favouring the 4026B
The SAA1064 and 4026B seem to be able to drive 12v displays so might even build my own from something like this
http://www.ebay.co.uk/itm/Green-1M-60-LED-Strip-Light-3528-SMD-Tape-Waterproof-Flexible-Strip-Lighting-12V-/161149634334?pt=UK_Home_Garden_Night_Lights_Fairy_Lights&hash=item258544471e
You should not have problems with multiple i2c devices in general provided you assign each a unique address.
I have occasions with RTC, RAM, multiple EEPROM, multiple IO expander chips, SAA1064 or compass modules, and more connected at the same time
marzan
As you know I wanted to build the same thing as you. Correct me if I'm wrong, but the only critical part is the clock stopping when the IR is interruptedUsing an RTC chip I had it collect the time when the the Ir is interrupted and it seemed to me that it didn't really matter if the display is a tad behind when running as long as it showed the correct times when it matters,so it was ok using more than one chip on the I2c bus. I treated the Picaxe chip as the ringmaster so to speak and let other chips do the hard work. I wanted to pursue my idea , but unfortunately other club stuff has taken priority at the moment.
Marz.
crazynight
Marz.
Yes you are correct I am still working on the same project as you Marzan, I abandoned i2c as my first build using the RTC and displays on i2c was not very reliable (think it was my soldering was the problem) so went down the route of reusing the old timers. v2 was a success (awaiting official testing and verification in just over a week) however the timers were small plus I am unable to source any more/replacements; sourcing large timers which go down to 100's of a second is going to cost hundreds of £ so I am now working on building standalone large timers capable of recording down to 100's of a second. Once they are built I should be able to interface them with v2. by my calculations the cost will be about £25 per timer and they will be about the size of an a4 sheet of paper.
I am learning very quickly with electronics there are always several ways to get to the same results ;)
crazynight
this is my design the picaxe will be running at 5v and not 12v with just a common 0v. each segment will be a strip of 3528 LEDs either 3 or 6.
