Clean-up an 8m2
Benjie
Hello there, I downloaded a complex code and after several runs I wanted to write some new code for totally different purposes on an 8M2. It happens that the loading and running the new code, I get the old one running too.
Is a reset command able to erase past code? Should I write a reset cmd on top of new codes?
Thanks to all.
I can't explain what is happening inside your chip.
You could try the "Erase" button in the "Download" Group on the "PICAXE" ribbon. That should erase any code in your PICAXE chip.
