hi folks,
See attached pdf. I've used a lot of these gadgets around the house for turning on night lights & sensing motion (driveway etc.). If using with a Picaxe, leave out JP & pull the Picaxe input high with ~10k...100k resistor. Pickup distance ~25 feet. You can power it with +5v if you like.
You can use as a standalone +12v LED strip light control by installing JP & powering from +12v (of course don't hook output to Picaxe).
I use them for my boat sheds with a 12v battery kept charged by a solar cell & regulator.
Note that they can be rigged for always or night-only operation.
Oops! See SR501 Labels.pdf for duplex box (USA style) drill template (ignore pushbutton holes (for another board))
Also terminal strip labels included
