Chat GPT very good but not quite perfect
Jeremy Leach
It's been a very long time since I avidly posted here, but I've recently had a little project on the go for an unusual van hear, and I was drawn back to the ease of use of the PICAXE .
As I'm very rusty on syntax and have lately been getting into AI in a big way, I thought I'd just tell ChatGPT what I wanted, that I was using an 08M, what my pinout needs to be, and just let it get on with it ! I'm very impressed that it has quite a deep understanding of PICAXEs and the code it spewed out is below. But I've had to tweak it a little because :
1. It omitted dirsC, so didn't specify the inputs and outputs - not good !
2. It originally thought it ok to use w0 and b0 as if they were completely separate variables - it didn't understand the nuance that b0 is part of w0. A pretty fundamental blooper.
I've told it off over these issues so hopefully it'll learn (I'm not exactly sure how it learns from user input though, but I'm guessing it must do). I'm just interested if anyone else has used AI to generate code and thought I'd share my experience.
symbol thermalSwitch = pinC.4       ' Input from thermal switch (e.g., physical pin 4 on 08M2)
symbol relayOutput = C.2            ' Output to the TIP31C (e.g., physical pin 5 on 08M2)
symbol ledOutput = C.1              ' Output to the LED (e.g., physical pin 6 on 08M2)
symbol failsafeTriggered = b0       ' Flag to track the failsafe state (0 = normal, 1 = failsafe)
symbol aliveCounter = b1            ' Timer variable for "I'm alive" flash
dirsC = %00000110                   ' Set C.2 and C.1 as outputs, others as inputs
high relayOutput                    ' Start with relay de-energized (heater ON by default)
low ledOutput                       ' Ensure LED is off initially
failsafeTriggered = 0
gosub startupFlash                  ' Flash the LED at startup
        if thermalSwitch = 1 and failsafeTriggered = 0 then
            gosub activateFailsafe   ' Trigger the failsafe if the thermal switch opens
        if failsafeTriggered = 1 then
            gosub alertFailsafe      ' Activate LED and buzzer in failsafe state
            gosub aliveFlash         ' Perform the "I'm alive" flash
        pause 100                   ' Small delay for loop stability
startupFlash:
    for b1 = 1 to 3                 ' Flash LED 3 times at startup
        high ledOutput              ' Turn LED ON
        pause 200                   ' Keep LED ON for 200ms
        low ledOutput               ' Turn LED OFF
        pause 200                   ' Keep LED OFF for 200ms
    next b1
activateFailsafe:
    failsafeTriggered = 1           ' Set failsafe state
    low relayOutput                 ' Energize the relay to turn OFF the heater
alertFailsafe:
    pause 500                       ' Keep LED ON for 500ms
    pause 500                       ' Keep LED OFF for 500ms
aliveFlash:
    aliveCounter = aliveCounter + 1 ' Increment the counter
    if aliveCounter >= 50 then      ' ~5 seconds (50 x 100ms loop pauses)
        high ledOutput              ' Brief flash of LED
        pause 100                   ' Keep LED ON for 100ms
        aliveCounter = 0            ' Reset counter
You could probably omit that DIRs command ... setting pins HIGH or LOW automatically makes them outputs ... and I believe pins default to input at reset.
So did this code compile and work as expected?
Yes, ChatGPT is pretty crazy! And it's only getting better! It's fun to play with for sure!
I've had to make a couple more tweaks but only because my circuit design was a bit different to what I'd told it. It's all working fine now and I've got to say, it saved me a lot of time typing and refreshing my memory about syntax.
Ah yes I'd forgotten that about the IO direction being set when used - cheers !
It's interesting how engineering types immediately realise that AI 'is only going to get better' and the huge potential that implies. I feel many are still missing the point. I've recently got into two-way real time chats with Google Gemini - quite amazing. I'm using Chat GPT daily as an assistant for (mainly) C# coding and it's fantastic, and has taught me such a lot about coding in more modern ways.
My understaning is that within a single session these LLMs have all learnt from your responses and providing feedback to the LLM to try and get it to generate a more correct answer, e.g. like telling it that b0 is a part of w0, is what is referred to "Prompt Engineering".
Whether any of the LLMs add what you've taught them to the underlying model, so that they can use they info you gave them in their answers to other people's queries, is a different issue.
I guess a way to test if it's "learning" is to go back and ask it to generate the same code based on the same conditions you gave it before (chat GPT chats are stored in history, so you should be able to go back and re-create the question) ... see if it "learned" from your correction. I just asked it if it knew about PICAXE BYTE and WORD variables, and it said it did, explained how W0 is made of B0 and B1 and gave a small sample of code putting a variable into B0 and another into W1 and then "debug" for both.
However, it's very difficult to know what these LLMs are just parroting back vs. what they are putting together based on "learning"
After I corrected it about B0 and W0 yesterday it said I was right and modified the code but no apology :).
I've noticed with Chat GPT that each conversation topic seems to be isolated memory wise, as if each thread spawns a new 'person' you are speaking with. For example after having had a long discussion yesterday about my heating system details, it got so familiar with all my terminology to the point it was making me laugh. Then this morning I mistakenly started a fresh chat on the topic and it was as if I was talking to a separate person who I'd never spoken to about it before ! But when I appended to my old chat it remembered everything.
If an AI system were to apply your corrections across the system, that would make it wide open to malicious corrections. Hopefully, some serious fact-checking can be applied then before it accepts a correction.
I am also relying on ChatGPT for a lot of answers. But Caveat Emptor! You should never accept them at face value, at least not yet.
One must still go thru any answer with a fine toothed comb.
My concern is that many people now seem to have absolutely blind faith in it, not understanding AI's limitations.
IF you pay attention to the "Artificial" part of AI, you're more likely to expect less-than-perfect answers at any point in time.
When/if I can pose "I want PICAXE code to read distance via I2C from a VL6180X IR laser ranging device." and get a functional answer, I'll accept that it's at least close to ready for prime time.
AliExpress has the 0-50cm and the 0-200cm chips for under $2.50US + shipping and the 0-400cm chip for under $5.00US + shipping (different part numbers, but all in the same family). One 50cm, two 200cm and one 400cm were under $12US with shipping today. All the interfacing I've seen so far is Arduino (Polulu has a library for it) but the datasheet is ONLY 87 pages and I suspect the basic single read of distance might be do-able from a PICAXE. When I'm neither in serious pain nor lost in multiple Rx pain med, that's a challenge for me because I'm curious. The Arduino library does a LOT but what I've read so far in the datasheet has me thinking that you should be able do the setup to do single, async distance reads with something simpler. I don't need the light level in Lux or the average of X reads or any of a bunch of other things the chip can do, including continuous motion distance reading. Just a one-at-a-time "Point and click" read the distance as a proof of concept.
Did I mention that I once worked in a corporate "Skunkworks" where computer system users brought their "I need X, but our support group tells me it can't be done" requests so I have experience doing the "can't be done"? ;-)
I don't have a VL6180X device near me ... but this code seems feasible ...
symbol I2CAddress = $52    ' Default 7-bit address of VL6180X shifted left for PICAXE (8-bit)
symbol REG_SYSRANGE_START = $18 ' Register to initiate a range measurement
symbol RESULT_RANGE_VAL = $62  ' Register containing the range result
symbol range = b0   ' Variable to store the range result
' Initialize the PICAXE
hi2csetup i2cmaster, I2CAddress, i2cfast_16 ' Set up I2C communication
' Main program loop
    ' Start a range measurement
    hi2cout REG_SYSRANGE_START, (1)
    ' Wait for the measurement to complete (~10ms)
    pause 10
    ' Read the range result
    hi2cin RESULT_RANGE_VAL, (range)
    ' Send the range result over serial output
    sertxd("Range: ", #range, " mm", 13, 10)
    ' Wait a short while before next measurement
    pause 500
Code Explanation:​
  1. I2C Setup:
    • The hi2csetup command initializes the I2C communication with the VL6180X at its default address.
  2. Range Measurement:
    • Writing 1 to the REG_SYSRANGE_START register starts a single range measurement.
    • The program waits 10 milliseconds to allow the sensor to complete the measurement.
  3. Reading the Result:
    • The range result is read from the RESULT_RANGE_VAL register into the variable range.
  4. Serial Output:
    • The sertxd command sends the range value to the serial output in millimeters.
  5. Loop:
    • The process repeats every 500ms to provide continuous range updates.
Let me know if you need help adapting the code or troubleshooting!
That was generated based on this prompt:
Hello, can you please generate some PICAXE code for a 20X2 PICAXE to do the following: I'd like you
 to get distance via I2C from an VL6180X sensor. I'd like to get the range from the VL6180X and then display
 it via the serial output.
Back
