M michael boyd Member Jan 18, 2010 #1 How do I write the programming to make pins 23 to 26 output pins
P Pfrogs Member Jan 18, 2010 #2 michael boyd said: How do I write the programming to make pins 23 to 26 output pins Click to expand... See "let dirsA / dirsB / dirsC / dirsD =" in Picaxe's manual 2. Edit: just in case you ask, pins 23 to 26 in Picaxe 40X2 are actually set as C.4 to C.7 in programming. Last edited: Jan 18, 2010
M michael boyd Member Jan 18, 2010 #3 thanks for the quick reply This error message came up when I simulated the program Only portB pins can be used with servo! Does this mean that I cannot use these pins to control servos? Which are the portB pins?
P Pfrogs Member Jan 18, 2010 #4 Yes, if you check "Servo" command in Manual 2, you can read that "On X2 parts the servo commands only function on pin0 -pin7 (B.0 to B.7)". Please, refer to Manual 1, page 33 to see how 40X2 pins are assorted.
M michael boyd Member Jan 18, 2010 #5 thanks again for the quick reply I think it is time to reconstruct my project board and yes, I should read more
