Can't remember, and can't find, answer to this code problem
wapo54001
It has been years since I last programmed extensively, and now I'm in a new project and find I've forgotten just about everything about Picaxe programming, so I'm relearning as I go along.
Step_Direction is the symbol for C.2 -- it works fine in the first IF .. ELSE snippet, but I can't figure out how to use the Symbol when checking the status of the pin. Right now I'm using the work around pinC.2 = 1, I'd like to keep things consistent and use the "Step_Direction" and "HIGH" symbols instead.
How do I rewrite the "IF pinC.2 = 1" using the SYMBOLS "Step_Direction" and "HIGH"?
SYMBOL Step_Direction = C.2
        IF CmdCode = "J" THEN
            HIGH Step_Direction
        ELSE
            LOW Step_Direction
        ENDIF
    IF pinC.2 = 1 THEN
        Count_Total = Count_Total + Count_Actual MAX 10000
    ELSE
        Count_Total = Count_Total - Count_Actual MIN 1
    ENDIF
techElder
Well-known member
You could use two different symbols:
Step_Direction_IN = pinC.2
Step_Direction_OUT = C.2
I think. :D
'outpinC.2' would be the best option to determine what the state of the output pin is.
But I would personally have used a bit variable to set the state and then use that in an output routine to set the actual pin level and determine how it had been set.
wapo54001
hippy, I originally used a bit variable and ran into some kind of programming problem and changed my approach, but I'll revisit that and see if I can figure it out.
Thanks to techelder also for his suggestion.
Edit - tried the bit storage again, got it to work this time, very simple solution, thanks again.
