can't open port error
teemodel
Here is the error message I get - Error: Can't open port /dev/tty.usbserial-0000101D (err=2: no such file or directory)
Running an IMac with OSX 10.8.5.
I just fell off the turnip truck when it comes to ports.
Thx
Teemodel
I have downloaded the driver three times and when I open the installer it runs and says done. I have tried it without the AXE075 in and out. I cannot locate the driver on my hd. The cord appears under USB listings. The error message now reads "Error: Hardware not found on /dev/tty.usbserial-000013fdi". If I could find the driver I might be able to change the location to the one shown on the USB listing. Help!
Teemodel
You do not change the driver settings. They actually appear to be working ok.
What you do under File>options>port in the AXEpad software is type in the number of the port as it appears on your machine in /dev/ (e.g. /dev/tty.usbserial-000013FD) or whatever it may be.
Be very careful typing, do not confuse i with 1 and use the correct upper/lower case.
Thanks Techie. I was not aware of the option. The correct port worked but did not change permanently. Next time I loaded program it went back to the incorrect port no.. Can I make it permanent? Thx.
teemodel
Back
