can't install editor
Doug Raymond
I have just downloaded bas805.exe It took forever. Trouble is, I need to transfer it across network to use on an older computer which still has a serial port. I couldn't move it so I opened it. It began installing itself. I quickly cancelled the installation. Now it won't accept my password. Any help will be appreciated.
Copy it to the computer you want to install and then run using the *installation* (not forum) password that was emailed to you.
There is nothing in the software to stop it working and so it is most likely you are using the wrong password.
