Can not install current editor version --- SOLVED
I down loaded the current editor and tried to install. Gets to the point of looking for a disk or source for program editor.msi. Turns out that there are several sources of this file in the windows installation folder which were not removed apparently by previous patches, etc.
I point to the files in the source box during install and it stops, saying the file is not valid. I have tried it for each of the Program Editor.MSI files on my cpu.
How to install this?
Update:
I had archived a copy of Microsoft's Install Cleanup Application which they don't offer any more. I ran it and it removed all instances of Programming Editor.
I also had to delete a file in the Windows/system32 directory named srcvw4.dll manually
Then the new editor version installed normally.
Update:
