nickwoodrow
evening all!
I know how to use the count function to count and display each time a button is pressed. Is ther a simple code to count the pulse on an output pin?I am using a relay on output 7 to complete a circuit that fires the shutter on my camera. I am using a relay because I do not went to send any current down the lead into the camera. I hope this is correct (i have tested this for a thousand shots and every thing is ok -Nikon dslr .
If it is not possible with code, could I wire output 6 to another relay (or even take a pair of wires from pin 7 relay and attach them to an input! Would I damage the board or even your minds!? Once again sorry for my lack of what seems to be pretty basic noobie lack of electronic sense question. Thanks in advance. I am learning and suspecting I don't need a relay to complete a circuit for the camera, I suspect there is a more elegant way. . Picaxe 28 axe020
