Technoman
Hi
We are using Logicator in Full French version.
1) As some labels translated into French in the procedure menu (GOTO/go sub) are a little confusing for our students, we were switching between the French and the English version. In doing that, most of the blocks became grey, amongst them the ones in the Procedure menu. They remained grey even after we switched back to French. Is it a bug related to the full/shareware/limited version of the software?
2) We never used the "GOTO" block but looking closely when you double-click on it you see the list of procedures available. It looks like a subroutine call excepted, in this case, your procedure should not end by a return.
What is the purpose of this block as you may draw lines? Having a large number of blocks not seen on the screen at once? A good chance to end with a "spaghetti" type of flow sheet...
Are we correct?
Technoman
Are we correct?
Technoman
