OK coffee out and head scratching begin. This is a tough one, and I would really appreciate any feedback at all.
I'm trying to get my head around getting the picaxe to calculate checksums for a bit of hardware I am designing.
The Picaxe will be controlling an observatory dome and will be sending and receiving information to/from a PC. The hardware isn't the issue.
The PC has ASCOM software installed. ASCOM is an industry standard that allows many types of astronomy "software" to communicate with generic astronomy "hardware".
So I thought it would be logical to get the Picaxe to talk through ASCOM to the PC.
An example serial ASCOM message is as follows:
In DECIMAL:
016 002 001 000 252 002 016 003 000
The same string in ASCII:
DLE STX SOH NUL ü STX DLE ETX NUL
Now quoting from the serial protocol document:
Each of these segments is defined as follows:
<start> - Two character start sequence consisting of ASCII DLE and STX.
<addr> - One byte address ranging from 0 to 255.
<control> - One byte of control information.
<data> - 0 to 250 bytes of data.
<checksum> - Two bytes of checksum information.
<end> - Two character end sequence consisting of ASCII DLE and ETX.
So in the above example serial string (which I captured using Docklight), <addr> is 001, <control> is 000, data doesn't exist, and the two bytes of checksum data are in Decimal 252 002. There is also 000 at the end, which appears in the captured data, but does not exist in the documentation, so its probably an added on bit of data that doesnt conform to the official standard, and would be ignored by most programs.
Now the big question: I don't get how to calculate these two checksum decimal numbers from the message. 252 and 002.
The documentation states:
MNCP uses the two byte Fletcher's checksum to check data integrity. The checksum includes all data bytes and the address and control bytes. The checksum does not include the DLE characters added during character stuffing.
The checksum is calculated by the following procedure:
sum1 = 0;
sum2 = 0;
for (i = 0; i < length; i++) {
sum1 = (sum1 + message) % 255;
sum2 = (sum2 + sum1) % 255;
c1 = 255 - ((sum1 + sum2) % 255;
c2 = 255 - ((sum1 + c1) % 255;
c1 and c2 are then appended to the message. On the other end, the check is made by adding all of the message bytes and the two checksum bytes modulo 255. If the result is 0, the data is valid.
Thats where I get lost. I try to step through the calculation using the serial string I captured, but I never get 252 and 002 as the checksums. Any help appreciated.
In DECIMAL:
sum1 = 0;
sum2 = 0;
