Mathew Clayson
I would like to build a custom IR remote control using a picaxe. The remote is for LEGO. The LEGO company recently released the specs for it new IR power functions system. The RCX that LEGo sells is compatable with all of the IR codes. But the IR transmitter that they sell only supports momentary motor control, and I would like to use the PWM and single wire funtions as well.
http://philohome.com/pf/pf.htm
http://philohome.com/pf/LEGO_Power_Functions_RC.pdf
The hardware for this project seem very straight forward. It's the coding I'm unsure of. I've used the picaxe08m for several model train projects, and I'd like to use it here, but it may be lacking in code space. But it seems that coding all the bits in the contol code is beyond me, particually toggle and LRC bits.
If anyone has done something similar, I'd appreciate some pointers.
Mat
Mat
