Mycroft2152
Multi-meters are very handy, but sometimes you only need a quick check of the logic level. This is where a Logic Probe is used
This is a simple to build Logic Probe. A resistor, LED, a BIC pen body and some wire is all it takes.
This is a golden oldie, I think I first saw the design in one of Don Lancaster's Cookbooks.
It is not a cure-all, but gives a quick indication of a high state on a pin. One note of caution, it can load the circuit, so use it on outputs only.
There are a number of other excellent probe circuits out there. A bit more complicated, but without the possibility of loading the circuit under test. PHAnderson has a slick design using a PICAXE 08 that also captures pulses. With a bit a of shoehorning, it will fit in a pen body too (my next build).
Myc
Myc
