When it comes to drawing up PCBs, I use Protel Autotrax, which is available as a free download from the Altium website. It runs in DOS, and is a very powerful system. You can also find suitable graphics drivers (eg. 1024x768 resolution) from the Airborn web site. Do a Google search for both. I have also got a component library made by Silicon Chip magazine. I don't think it is available anymore, but I can upload it to my website if you wish.
Also, note that with Autotrax, you have to generate a Postscript document of your PCB file, so you will need GSView and Ghostscript to view and print your PCBs. It also does not come with a help file, so you will have to learn it yourself. It is a very logical program as you may find, so it is easy to learn.
When it comes to driving the LEDs, I would use a 4017 IC. You clock the input pin to switch to the next LED. Do a search for "4017 led chaser" and you will get circuit of 10 LED chasers. In order to have 11 LEDs, you will have to use two 4017 decade counters, and clock them both in the right order. That is, you clock one six times, then clock the other 5 times. In order to not make the other one repeat, study how the reset pin works. Sometimes discrete components are the best option.
Edited by - dannydig87 on 12/10/2006 05:07:33
