Bluetooth
friis
I want to set up a bluetooth connection between a sensor and Picaxe chip, and after checking the
net and the forum I would expect hc-05 in connection with the chip and hc-06 in connection with the
sensor. Is that OK?
best regards
torben
Technically it shouldn't matter in a one-to-one connection where there will be a PICAXE connected at both ends.
The HC-06 can be a slave only, waits for a connection to it, while the HC-05 can make a connection or wait for one to come in, so it would be logical to put the HC-06 on the sensor side so you can connect to it from your phone or laptop to test it.
You could just use HC-05 on both sides.
friis
Hi hippy,
Thank you. I will do it. I may come back with problems later.
best regards
torben
newplumber
Hi friis
I hope you get it done with no problems ...and it would be awesome to see (if its possible)
a simple schematic of your project and maybe some code ...cause someday I would like to try bluetoothing
but i understand if your always pushed for time
your friend
Mark
