Bluetooth electronics App
r1erick2
Hi, I have a HC-06 bluetooth serial adaptor connected to picaxe 08m2+ and I using an Bluetooth App, it is working correctly in a just single command, example: push bottons or any serial out text comunicacion, but if you want to use digital joystick or any slider doesn't work correctly. Please any help. Thank you.
Setfreq m8
Start:
Serin c.2,T9600_8,b0
Pause 50
Sertxd ("Real Value", #b0,13,10)
Pause 100
Goto start
App www.keuwl.com
Only in android BlueTooth Electronics.
When you say it doesn't work correctly; what does it do ?
I would guess that the phone app could be sending more than one byte of data and the code has to be adjusted for that but I couldn't find any documentation on what the app sends.
If you have any idea where that information would be it would be a great help if you could tell us where that is.
Looking at the RGB LED controller, it seems the app sends a character and then an number -
http://www.keuwl.com/electronics/rduino/bluet/02-pwm-leds
Using that example I would have expected to be able to read the data sent from the red fader with the following code, untested -
Setfreq m8
Start:
Serin c.2,T9600_8,b0, #w1
If b0 = "R" then
  Sertxd ("Red", #w1,13,10)
EndIf
Goto start
I agree with hippy. Those pause commands are resulting in the PICAXE skipping the successive characters. The pauses have no place in a program that is trying to receive serial data.
r1erick2
Im in the work right now but Thats true about the pauses, if i want to use more data bits i need to add something like that?
Start:
If b0 = "R" then
Serin c.2,T9600_8,b0, #w2
If b0 = "B" then
Sertxd ("Blue", #w2,13,10)
Serin c.2,T9600_8,b0, #w3
If b0 = "G" then
Sertxd ("Green", #w3,13,10)
EndIf
Goto start
If I use this code in the joystick?
Start:
If b0 = "X" then
Sertxd ("X", #w1,13,10)
If b0 = "Y" then
Sertxd ("Y", #w2,13,10)
Ifend
Goto start
Rather than consecutively read with separate SERIN commands you would probably be better off with something which does one SERIN and then determines what has been received. Something like -
#Picaxe 08M2
#Terminal 9600
#No_Data
Symbol rxdChar  = b0
Symbol rxdValue = w1
Symbol red      = w2
Symbol green    = w3
Symbol blue     = w4
SetFreq M8
Do
  SerIn C.2, T9600_8, rxdChar, #rxdValue
  Select Case rxdChar
    Case "R" : red   = rxdValue : Gosub Report
    Case "G" : green = rxdValue : Gosub Report
    Case "B" : blue  = rxdValue : Gosub Report
  End Select
Loop
Report:
  SerTxd( "R = ", #red,   TAB    )
  SerTxd( "G = ", #green, TAB    )
  SerTxd( "B = ", #blue,  CR, LF )
  Return
Or, very similar, for the joystick -
#Picaxe 08M2
#Terminal 9600
#No_Data
Symbol rxdChar  = b0
Symbol x        = w2
Symbol y        = w3
SetFreq M8
Do
  Select Case rxdChar
    Case "X" : x = rxdValue : Gosub Report
    Case "Y" : y = rxdValue : Gosub Report
  End Select
Loop
Report:
  SerTxd( "X = ", #x, TAB    )
  SerTxd( "Y = ", #y, CR, LF )
  Return
Bill.b
Hi
This is a sample of the code I have used to control a robot using HC 06.
The Bluetooth app I am using is roboremo.
each button is assigned a LETTER ie A - I and a slider for speed control With ID "r".
The output range set to 0 to 255,
The HC 06 sends the slider data in 5 bytes - ID, space, units, 10s and 100s this requires some decoding in the program.
Hope this is of some help
Bill
#picaxe 40X2
Setfreq M16
#No_Data
#No_Table
DisableBod
Symbol M1PWM  = C.2  'Motor 1 & 2 Speed (PWM) output
symbol SpeedCount  = w21
RemoteIn:
REM Controlling with BT module HC-06 - PICAXE
'b12 = 0  ;clearing memory for commands
serin [2000],a.0,T9600_16,b12,b13,b14,b15,b16 ;reading from bluetooth (waits 2s for character)
  pause 50
'select b12  ;selection depending on received character
select case b12
case 65
gosub FWDFast 'FWD
case 66
gosub TurnRight 'FWD Right
case 67
gosub TurnRightR 'REV Right
case 68
gosub BackFast 'REV
case 69
gosub TurnLeftR 'Rev Left
case 70
gosub Turnleft 'FWD Left
case 71
gosub stopm 'Stop
case 72
VoiceNo = 33
GOSUB voice 'camera on
case 73
VoiceNo = 34
  GOSUB voice  'camera off
case 74
Pwmduty M1PWM,900
gosub TurnAround2
case 75
Pwmduty M1PWM,900
gosub TurnAround
case 113 'Speed
b17= b14 -48
if b15 = 10 then
b18 = 0
goto loopend
b18 = b15 -48
if b16 = 10 then
b19 = 0
b19 = b16 - 48
end select
loopend:
b7= b17 * 10 + b18 * 10 + b19 'Convert from ASCII to Binary
SpeedCount = b7 * 3 + 200 'Speed count for PWM = 200 to 950
Pwmduty M1PWM,speedCount
return  ;end of loop
