[BEAM] SBSE v1 - 08m2 based Solar Engine
JamesWhite
After toasting my last 1381 voltage trigger for a 'miller' solar engine, I decided I wanted to try a new design. I decided to use a 08m2 to sample the storage capacitor's voltage and dump power (provide an enable low all systems go signal) to my other circuitry. It triggers only if the voltage is over a pre-set level and only if the voltage has not risen between samples, thus allowing triggering based on solar cell output, not just the trigger voltage. In BEAM lingo it's a Type 3 SE.
Here is my blog w/ more info:
http://geppettosworkbench.blogspot.com/2013/09/sbse-v1-new-picaxe-08m2-based-solar.html
-James
'                                _                       _
'                            ___| |__  ___  ___  /\   /\/ |
'                           / __| '_ \/ __|/ _ \ \ \ / /| |
'                           \__ \ |_) \__ \  __/  \ V /_| |	James White
'                           |___/_.__/|___/\___|   \_/(_)_|	9/20/13
'                          SMART BEAM SOLAR ENGINE TYPE 3
'   SERIAL OUT
'  <-----------------------------------------------+			|===  Nap Reference  ===
'   GROUND                                         |			|     value  time
'  <-------------------------------------------+   |			| 	0  = 18ms
'   SERIAL IN                                  |   |			|	1  = 32ms
'  >-------------------------------+           |   |			|	3  = 72ms
'   ENABLE                 ____    |    ____   |   |			|	4  = 144ms
'  <---------------+  +---(____)---+---(____)--+   |			|	5  = 288ms
'                  |  |     22k          10k   |   |			|	6  = 576ms
'   Vcc           _|__|_    .----+--+----.     |   |			|	7  = 1.1s
'  <----+--------/ |  | \--[|Vcc '--' Gnd|]----+   |			|	8  = 2.3s
'       |          |  |     |   PICAXE   |         |			|	9  = 4s
'       |          |  +----[|C.5      C.0|]--------+--|<|--+	|	10 = 8s
'       |   ____   |        |    08M2    |           1N914 |	|	11 = 16s
'       +--(____)--+-------[|C.4      C.1|]----------------+	|	12 = 32s
'       |   100k            |            |                 |	|	13 = 64s
'       |               NC [|C.3      C.2|] NC             |	|	14 = 128s
'       |                        ____                      |
'       +-----------------------(____)---------------------+
'                                 10k
' ======  Constants  ======
  symbol      TestVin = c.0				' connect to cathode of diode
  symbol          Vin = c.1				' connect to anode of diode and to 10k pullup resistor
  symbol      DumpPWR = c.4				' enable low output
' ======  Variables  ======
  symbol TriggerLevel = b0				' min voltage to dump power  (set @ 45 for 3v trigger)
  symbol  TestResults = b1				' results from voltage test
  symbol PreviousTest = b2				' previous test results to compare to most recent test
  symbol     TestFreq = b3				' how long to wait in between checking the voltage
  symbol    MaxOnTime = b4				' maximum amount of time to dump power in one go
' ======  Directives ======
  #picaxe 08m2
  #no_data
  #no_end
' ======================================= Begin Program =======================================
  setfreq k31						' set clock speed to its lowest setting to conserve power
  high DumpPWR						' this pin has a 10k pullup
  high TestVin						' we want this pin high until time to sample the voltage
  let TriggerLevel = 45					' this number decides min voltage at which the SE will trigger, increase to lower and decrease to raise trigger voltage
  let PreviousTest = 255				' start with a zero volt reading
  let TestFreq = 8					' this number decides how long to wait between samples
  let MaxOnTime = 9					' maximum amount of time to dump power
test:
  nap TestFreq
  low TestVin
  readadc Vin, TestResults
  high TestVin
  if TestResults >= TriggerLevel then goto test
  if TestResults < PreviousTest then goto save
  goto enable
save:
  let PreviousTest = TestResults
  goto test
enable:
  low DumpPWR
  nap MaxOnTime
  reset
JamesWhite
Thanks MPep.
I don't have any videos or anything up yet about the bot I put this SE into. I had to use a SMD 08m2 freeformed to the underside of the .22F supercap because the available space I had was miniscule.
I'll post here though when I add more info, pictures and a video on the little turbot.
-James
JamesWhite
I just realized last night that with the calibadc command you can accomplish the same thing (measuring a 'fixed' voltage reference) but without any pins or external parts. RTFM, Right?
Still, it could be of use for an obsolete 08m though...
