CommanderLake
I'm trying to think of the best way to make a basic menu system with: a PICAXE 14M2, 3 tactile switches(little buttons) and an OLED display controlled by the AXE133 firmware on a separate 18M2
The 3 buttons being set, plus and minus.
I would start by setting an interrupt for the set button to enter the menu "setint %00000100,%00000100,C"
then use the plus and minus buttons to flick through the options
then modify the option on the second line with the plus and minus buttons
and a final press of the set button to save the setting and return to displaying the main volume level
It's for a 7.1 amplifier with 2x 4 channel volume control chips daisy chained and controlled by the 14M2
so the menu options will be things like: LFE Gain (in dB) and Display Brightness
Any tips or suggestions for programming this in basic are greatly appreciated.
