I know this is probably a very simple question to most of you on this forum but I'm new to electronics and we all have to start somewhere!
I want to use a Picaxe pin (e.g C.5 on a 28X2) to switch a GPS module on and off. The instructions for the GPS module says there is an enable pin specifically for this and it is pulled high with a 10K resistor. When this pin is pulled to ground, it will turn off the GPS module.
Could somebody explain (in very simple terms, ideally with a diagram), how I wire the Picaxe pin to the GPS enable pin please?
Thank you!
Thank you!
