I'm using a AXE200 28X2 module to drive a L298 motor driver. Everything is now working but I want to be able to monitor the current through each motor using the voltage across two .5 ohm resistors on the current sense pins.
The inputs are on pin A.3 (ADC3) and B.4(ADC11), virtually all the pins between are outputs, the manual says something about having to set ADC sequentially, will this mean I can't use B.4(ADC11)? ADC0 & 1 are available but would mean using an additional jumper wire which I'd rather avoid. What ADCsetup & readADC command do I need, what would happen if I attempt to read B.4 without an ADCsetup command?
Thanks in advance.
Thanks in advance.
