Ninja MacNinja
I am fairly new to PICAXE programming and Im having an issue with a piece of code.
I have bought the AXE134Y OLED display as I plan to use it in a project. This issue I am having is with the test command below. It comes up with a syntax error, which is also below.
Command
init: pause 500 ; wait for display to initialise
main: serout B.7,N2400,(254,128) ; move to start of first line
serout B.7,N2400,(“Hello!123”) ; output text
end
Error:
serout B.7,N2400,(“Hello!”) ; output text
Syntax error on line 3 at/before position 18
Error: Illegal character: ((0xFFFFFF93))
Is there some sort of firmware that needs to be downloaded onto the chip before I can use it? As I said I am fairly new to PICAXE having only used (barely) Assembly Language. Any assistance would be greatly appreciated.
Thanks
Command
end
Error:
Thanks
