Hi folks.
I am using an old Win 2K laptop, and the PE installed fine, and also so did the AXE027 driver utility thing.
When I plug in the AXE07 after having installed the drivers, Win 2K says it has found it, and ID's it correctly, but the following window where it asks to install it fails with the message that it could not find the necessary drivers.
How can that be?
Windoze knows it is there, ID's it correctly, but then says it can't see it or install it, cos the drivers are not installed.
Anyone got any hints?
EDIT: Nevermind. A little good old fashioned Windoze pointing fixed the problem. I told the driver installer follower window thingy to look in the AXE027 USB Driver folder under Program Files/Programming Editor, and away it went.
Mods can delete this post.
How can that be?
