Hi Folks,
This is just to advise that my AXE027 cable has failed.
It was during a run of programming on a 08M2.
Everything was going OK when it suddenly stopped.
Previous to this, I haven't had any problem with it - always worked OK.
I checked the serial input line using the Test button under Options.
Normally when the Test is pressed you should see about +4.7V.
In this case it was seen to be -4.7V - opposite polarity!
So, something has happened to its USB interface.
I confirmed that the problem was in the AXE027 by using another AXE027, which worked OK.
Anyway, this is just to let you know of the failure - no help required really.
kenmac
kenmac
