Hi, recently i got two axe022 protoboards, and have had quite a few in the past.
Usually the first thing i do is install 2.54mm header pins to all four ports, and the
pns port. I was quite surprised when i found the pins were far too large!
Seeing as these are through plated holes, therefore drilling them out would cause
problems as i found out.
Have the hole diameters changed for a reason?, because on my older boards i could quite
easily fit molex headers.
Are there similar headers that will fit?
Thanks john
Thanks john
