Ninja MacNinja
Hello again guys I have some queries regarding the transmission of my code. I have my weather station now working and have tested all the results and they look good. I am now thinking about having the OLED screen inside as this will be more practical. I have the AXE 213 Radio board and the RFA001 and have managed to send and receive some data from the two units onto the OLED. Apart from some signal issues that I'm having the information is not being displayed in the correct order/lines. I am using the single wire method as I currently only have one micro-controller. I have attached the code I am using together with a picture of the message being displayed and of the receiver. Has anyone else encountered this issue and if so, how did you resolve this.
With regards to the signal issues, I am just using a piece of single core wire, which is not providing a consistent signal even with the boards in the same room. It seems to help if I prop up the unused send cable, which made me think there may be a short circuit. I tested and checked the board for anything like this, but it looks the same as the diagram. Is this a common issue. I turned off all the electrical equipment in the room but this did not resolve the issue.
Okay, just tried to upload the pictures, but it is not working. If you need them I'll work it out and post later.
Any input is would be appreciated.
Thanks
View attachment First transmit code.bas
Thanks
