Hi (first post here)
I'm starting to assemble a datalogger from the AXE 110 kit. Along with it I got the AXE 033 LCD and the AXE111 EEPROM. Now that I've had the documentation to read in detail ...and slowly... it sounds like the AXE 110 won't output to the LCD and the EEPROM simultaneously. Not even alternate from one to the other because they both need Output 6.
Have I misunderstood or is that true? Any work-arounds that you know of?
A switch on the container so that at you can choose either "store" OR "display"?
PS this project is a replacement for my old PICAXE datalogger, which was built on waferboard from a kit you can see here: http://www.thebackshed.com/windmill/assemblyA.asp#4
My datalogger monitored the power output of a windmill that I built, so that I could evaluate the changes and improvements as I optimized the machine. This "second generation" is meant to run continuously and provide power info on the LCD. I also want to eliminate having a laptop computer running all the time to collect the data, but can it use both the EEPROM and the LCD?
Thanks
Steve
Love this PICAXE stuff. I can acually understand it after reading the manuals a couple of times.
Thanks
Steve
