Need a little help with a project I'm doing for uni.
I'm trying to make a programable stage truck. You basically give it a list of movements and it will carry them out on the push of a go button.
Components So Far
1x Picaxe 28 with motor driver
2x 12 V wheel chair motors + batteries
1x emergency stop button
1x go button
4x ultrasonic range sensors
I just need to check that the way I'm going about this is right.
I plan to make 4 relay circuits. these will control forwards and backwards movement on each motor. The relays will be switched directly from the outputs on the picaxe controller. The ultrasonic sensors will pause the truck if there is an obstruction in its way.
Would I be able to run the 12V motors directly off the controller board and get rid of the relays?
Cheers
Mike
Components So Far
1x go button
Cheers
Mike
