ASCII character set used by PE6
#1
Afternoon folks,
Bit of an odd one, but which ASCII character set is used by PE6?
As far as I'm aware, the "standard" 0-127 ASCII characters have never changed, but I seem to be finding conflicting information with regards to the "extended" character set... is it the same character set used in Word? (UK keyboard)
Cheers!
#2
Depends on how you are using them. Most use of 'extended' is within LCD or OLED work, and they all vary, so you need to check which font set your actual module uses (by looking at its specific datasheet).
