Aries
I use the option Diagnostics->Display Pre-processor Output quite often to check whether conditional coding (selected via #define) has worked as it should, or to compare different versions of a program which has #include files.
On Windows 11, Picaxe "encounters an error" after "Check syntax" with the option set. No more information than that, but I have worked out that Picaxe uses Wordpad to display the output, and the last Windows 11 update removed Wordpad once and for all.
If you are in this position, it is possible to copy Wordpad from a Windows 10 machine or, if you haven't had the upgrade yet, to save it on your WIndows 11 machine.
There's an explanation of how to do it here ...
www.pcworld.com
WordPad is now gone from Windows 11. Here's how to bring it back
With the arrival of Windows 11 version 24H2, WordPad is officially gone. Want to keep using it? You're in luck.
