On this page (thank you for having it available)
http://drvernacula.topcities.com/400_metre.htm
In the second paragraph it says "The transmitter is rated at 4000 metres and it may well go that far when listening for a tone on a scanner"
I'm still trying to learn how to send "data" with RF and Picaxe... but all I want to do at the moment, is turn on an output pin when the RF receiver "hears" the transmitter is active. I have been using a cheap 315mhz set, with an encoder and decoder, because they came with them already. Now I want to try using Picaxes to replace the encoder and decoder, because later on I want to add more features to my projects.
Having trouble explaining here, so I'll just ask directly....Can the typical cheap RF units, being used by many of you guys, send and receive tones instead of "data"??? If longer distances are possible this way I want to try it...
