I'm going to anodize and dye some aluminium picaxe project housings. Anodizing (dependent on the surface area to be anodized) requires a 12V high I power supply. I'll need around 200 amps. High I 12V power supplies are big bucks and I can't afford to buy one as I'm going to lash out on a TIG. (I'd build that too if it was feasible).
As indicated in another thread I came across this article by a Ham and have decided to use this method to mod a microwave transformer to get the current I need.
http://www.users.on.net/~endsodds/psrewind.htm
Supposing I can draw 20 amps from each transformer it occurred to me I could make a sort of variable I supply by having, say, 10 transformers in parallel.
Each transformer is individually switched to the ~240 supply. The 12V output of each is rectified individually and connected to a common output. As I need more current ( because I'm anodizing larger objects) I simply switch on more transformers.
Is there any reason this approach wouldn't work?
I'm off to the tip tomorrow to scrounge dead microwave ovens and thought I better check in before I debased myself (even further).
(Hand wringers need not reply to this thread. ie. Ooohhhhh.... you might get fried by the nasty ~240.)
