Tricky Dicky
Hi Guys
I have a GCSE student who is designing a bite alarm for his coursework project. The current thinking is that this will be a rod rest mounted device triggered by the rapid movement of the fishing line on a pulley or roller as a fish bites.
The input will be a sloted darlington opto-isolator through which a sloted wheel will rotate producing a series of output pulses.
The pulses are to be counted by a counter (a 4017B) and after a yet to be determined count this will eventually trigger an output such as an LED and possibly a piezzo sounder.
In order to filter out low level frequency pulses caused by ripples on the water the counter is constantly reset by a CMOS based astable set to produce short ons and long offs running roughly at 1Hz (this frequency will be fine tuned with some experimentation).
The result is that low frequency pulses never reach the trigger point before the count is reset and only much higher frequency pulses result in an alarm.
I have simulated this hardware solution and it works but it is already a two IC solution and that is before the final driver stage of either a latch or monostable is added to drive the final output LED or piezzo. From past experience this looks like the PCB is going to be much larger than would be ideal.
I feel sure a much simpler solution exists using PICAXE but the code has got me stumped. So I am looking for ideas. If it helps we have PICAXE 08Ms, 18's, 18A's, 18X's and 28's available, so knock yourselves out!
Richard
Â
Richard
Â
