Android app
davidwf
I'm sure it's been asked many times but is there or will there ever be an app for Android to connect to PIC......even if we can't program it, something to monitor any sertxd commands would be helpful when debugging
jscottb
Active member
Still new to the picaxe world, but I assume you should be able to configure an HC05 module at a baud rate you can do picaxe talking with. You may need to do some level shifting on the RX line for the module. I have an "app" I did it using the MIT App inventor a few years back. It's found at: http://ai2.appinventor.mit.edu/#5451075859775488. It allows sending data back and forth between the uC and Android via BT. See the about blurb for the commands.
kfjl
Android or whatever to PIC or whatever.
My video was not very good but dailymotion has made it as bad as dailymotion.
