bit1 = pinc.1 and pinc.2 and pinc.3
if bit1 = 1 then high c.4
else low c.4
How did you add the third, and what errors did you get?If I add a 3rd, I get errors with the simulator....
It was a "syntax" error, I wished now I had "snipped" the screen before I closed it but after re-entering the code, it works. Thanks to all.....How did you add the third, and what errors did you get?
Just for the record, a syntax error is nothing to do with the simulator - it is a problem with your code and the compiler (and I would put money on it being the code and not the compiler)It was a "syntax" error,
