just wanted to get some verification of the top tab for this voltage reg AMS1117 5v
the datasheet says the top tab for the T0 252 is also v+ out so i just wanted to confirm with anyone who has knowledge of this or has used it that the same applies to the SOT 223 as this info is only printed directly above the other device.
would rather check first than assume it is, just incase it is a thermal heatsink of sorts instead.
thanks.
View attachment datasheet (1).pdf
thanks.
