Amateur Radio - Various Projects
Gavinn
Hi all,
I'm a radio ham and have used the PICAXE for a few projects now. Scematics, board layout and PICAXE code is available on all projects which you are welcome to use...
Here is a link to all my projects: http://project.geekshed.co.uk
I hope some are of use to others...
PICAXE display for Ham radio Amplifier
Hi All,
I designed my own Graphic LCD which communicates with a PICAXE.
The PICAXE/Station monitor PCB collects the data and sends it to a display.
The Graphic LCD has got a piggy back PCB behind it which translates the commands into something the Graphic LCD understands.
In that way the PICAXE software is kept simple and fast :D.
So for other HAMS in Australia, Holland, France and the USA have been building the kit as well, with good results.
More info on this project can be found here ->
http://www.vk4dd.com/forum/viewtopic.php?f=11&t=26
and here
http://www.vk4dd.com/forum/viewtopic.php?f=11&t=32
and here
http://www.vk4dd.com/forum/viewtopic.php?f=11&t=27
If your intrested in making your own HF,6m or 2m amp
than there is lots of other intresting circuit boards or info avaliable on our
site.
73's from VK
Back
