the old fart
There is a hole, on the board, to fit a wire aerial.
if I knew what a 1/4 wave bit of wire to use I would try it.
LOS (line of sight) is way to vague as an indication on its own, as even if the TX and RX can see each other what is close to the path, such as the ground, can have a significant effect.bought these because I needed the 500M range.
My point is that the information, in the rev-ed datasheet, is incorrect as to los distance using standard erf ceramic aerial.LOS (line of sight) is way to vague as an indication on its own, as even if the TX and RX can see each other what is close to the path, such as the ground, can have a significant effect.
500M LOS between two tall towers or buildings is for instance very easy to achieve indeed. At ground level that could reduce to 50M or less.
The information in the datasheet looks correct to me. An ERF with a ceramic aerial can have a range of 500m LOS when that is to an XRF with whip aerial as shown in the Wireless Things data chart.My point is that the information, in the rev-ed datasheet, is incorrect as to los distance using standard erf ceramic aerial.
the ERFv2.0 are SRF moduals mounted to an ERF board.Looks like the ERF may have been dropped now, not listed on 'wirelessthings.net' any more, well not as a purchasable item anyaway.
So maybe it would have to XRF's and add a 1/4 wave whip.
Neil.
2 ERF's with ceramic chips will only work upto 150M. as I read from the datasheet.The information in the datasheet looks correct to me. An ERF with a ceramic aerial can have a range of 500m LOS when that is to an XRF with whip aerial as shown in the Wireless Things data chart.
We would not simply make up datasheet figures so those would have been based on manufacturer supplied information. It may be that, at the time, we were only informed of the maximal range and not any qualifications which came with that figure.
None the less; it does appear to me that 500m LOS is the maximal range of an ERF with ceramic aerial.
As @srnet indicated, achieving range is something of a black art. The nature of the surrounding area, the objects within it and the proximity of the ground has a massive impact on the range even if the receiving antenna is visible from the transmitting antenna. I have played around with ERFs, XRFs, SRFs and ARFs as well as XBees, Xbee-Pros and so forth and I am astonished at how difficult it is to design for and predict range. I have a drawerful of various (?)RF units, antennae and so forth from when I first ventured into this field and "learning experience". Even the relationship between the ERF and the associated circuit board together with the cables that connect them make for a substantial difference in range, as does ceramic chip antenna orientation. Also, the presence of other devices in the area transmitting on the same or near frequency matters greatly. When it rains and the trees are wet the range is very different to when the weather is dry. And I cannot account for the impact on transmission over a large outdoor miniature railway track - the rails are bound to have an effect. The LOS range quoted by manufacturers assumes optimum conditions and these are rarely found in practice. The manufacturer cannot really be expected to give a "typical usage" range because a typical usage is so difficult to define. As srnet indicates, a reduction down to 10% of the quoted LOS figure is often the case in practice when less-than-optimal boards, instrument cases, antennae and the environment take their toll. Conversely, there are guarded claims of much greater ranges - have a look at this representation of the XRF module; http://www.farnell.com/datasheets/1973754.pdf "We have had reports from customers sending data over more than 3 Km using the standard supplied whip antennas!" Well I am not one of those customers...2 ERF's with ceramic chips will only work upto 150M. as I read from the datasheet.
yes possibly upto 500M to XRF chip. but I have 4 ERF units.
Will see what performace I can get with new whip antennas.
How very interesting...so much for impedance matching! @srnet - comment from the expert??reply from Ciesco re aerial,
"We use a 1/4 wave whip and do not usually bother to remove the ceramic and the small capacitor and inductor. "
I think that @srnet already provided this advice in post 46;I understand 1/4 1/2 3/4 and full wave antenna lengths.
Am I right in assuming that the longer the antenna, the better the reception?
TOF
I think that you are better off looking at adding a ground-plane and looking at "antenna tuning" as he suggests. It is a little tedious trying out various antenna lengths (taking off only a mm. or so at a time) and wandering off to check and note the range that can be achieved, but it is probably the best approach. I find that the antenna supplied with the ARF unit is really effective and these can be obtained quite easily from the major suppliers if you would like to fit them to the ERF units. Note that, despite the apparent length, these are still quarter wave antennae internally. I doubt that you will get anything better without going to directional antennae.A 1/4 wave is a good place to start, but an exact 1/4 wave is unlikely to be the best length, especially without an effective ground plane.
A 1/4 wave with radials (groundplane) should perform better and a 1/2 wave is about as bad a length as you can get, 3/4 wave length in the next resonant length. .
When comparing antennas like this you really do have to take variables such as 'bodies' out of the picture, a large open field is best, between hilltops etc.
Its also important to measure the distance at which comms fails with the various antenna changes, in that way you can calculate the dB difference in antenna efficiency and this is a very useful number indeed.
In my experience the output matching of these low end RF modules tends not to be very accurate. They may well be designed for around 50ohm, in order to be a good match into co-ax cable etc. But the actual impedance can be different, so it should be no surprise that the whip antenna length for maximum transmitted signal can be different to what a calculator suggests.How very interesting...so much for impedance matching! @srnet - comment
No.I understand 1/4 1/2 3/4 and full wave antenna lengths.
TOF
thanks srnet,No.
For maximum radiated power, the impedance of the antenna needs to match the impedance of the RF output stage of the radio module.
The output stages are most often designed around an impedance of 50ohm, which is a good match to a 1/4wave with ground plane or a dipole.
The impedance of an end fed 1/2 wave antenna is around 2000ohms, and thus a very bad match to the radio module, and very little power gets transferred to the antenna.
I've been trawling the internet, re ground plane.The output stages are most often designed around an impedance of 50ohm, which is a good match to a 1/4wave with ground plane or a dipole.
Thanks for link srnet, will have a read.The general arrangement is for a 1/4 wave vertical (the fed part) and then 4 x 1/4 radials, 90 degrees apart, connected to ground/0v.
http://www.ccars.org/projects/2mgp/tech_2mgp.htm
Although for a simple installation guitar wire (Ernie Ball Custom Gauge 13) is fine, bend over the cut ends to avoid stabbing injuries.
