Adjustable clock generator
mattg
Hello! I am trying to use a stepper motor driver chip (STK672-330) to drive a stepper motor. Can i use a 40X1 to generate an adjustable clock signal (0 to 50Khz)? if so, how? Thanks!
eclectic
Hallo mattg, and welcome to the Forum
An adjustable signal sounds perfectly feasible, with a 40X1
Can you post a link to the driver datasheet please?
Then it will be easier for folks to offer advice.
e
eclectic
Thanks matt.
Are you familiar with the pwwmout command?
It'll provide a background "clock" from ~3900 Hz to 50 kHz
Below 3900, other methods are available.
Can you give a little more background to your project please?
e
Andrew Cowan
You should use the PWMout command to make the signal, probably with a duty cycle of 50%.
Bear in mind that this can only be used on certain pins.
A
mattg
Thank you for the advice, i will look into it. I am new to microcontrollers alltogether and am just starting to play with these.
As for a project, i really dont have anything specific planned, i just want to see if i can get this to work.
eclectic
OK.
Please download the Programming Editor,
then you can use the excellent manuals
and the Simulator.
e
