I want to use a Picaxe to control the speed of an AC motor (fan). I know, I know but I am qualified to use the main power so that is not the issue. I already tried a 12 starter motor but it did not work ... too slow.
What I want to know is if folks think it is possible to use a relay of sorts and switch it with the PWM command to vary the speed of the AC motor? Or, a better option.
I am trying to build a device to measure the air flow thru an automotive mass air flow meter that is used on an automotive engine. They put out a signal from 0-5v based on the volume of air going thru them but apparently the data is rather secret ... so I will have to do it myself and build a chart/curve. I need a variable speed fan for this and only have an AC unit to work with.
The car computer uses the MAF to calculate volumetric efficiency and to calculate the pulse width of the fuel injector so it supplied the proper amount of fuel. Accordingly, the MAF table and accuracy is quit important. I am developing a turbocharger installation for a race engine.
Thanks
Thanks
