mhalbern
What code and hardware will put a PICAXE 08M2 into a state of absolute lowest power (that is, current) after completing program execution?
I am using a 3 volt supply, DISABLEBOD, 31k clock, and 47K ohm pull-downs on all unused inputs. According to the manual, at the end of my program, using the END command should get me there.
My circuit measurements indicate about 12 microamperes after the END command has executed on the PICAXE power supply pin.
Is that the best (lowest) I can expect?
Thank you for a reply.
