OK,
I read most of the posts on AtoD and it seems that if your project is battery powered you cannot use the AtoD in the Picaxe to monitor it's own power supply. As the battery looses voltage the reference moves with it, as has been described in other posts. I had hoped to have a battery test in my current project but this has caused a bit of a glitch. I assume all three batteries will degrade at equal rates so measuring one cell will not help, what if I were to use a reference voltage say 2.5 VDC and read it on one AtoD and then a single cell (of the three) on another? The reference will still move but the 2.5 will be a constant to work out the battery voltage.
Just trying to get out of the box here.
Regards,
PFM
Regards,
PFM
