Hello,
I last posted on this forum in April 2011 with an enquiry about a Picaxe controlling a garden water sprinkler. Owing to a fall from a step ladder whilst folding double bed size sheets, I have been out of action for a while. Therefore, before I continue with this enquiry may I offer thanks to those who took the time to sit down and write suggestions. I did eventually solve the sprinkler problem by acquiring a new diaphragm which returned the original machine to normal working order.
My latest quest for advice follows this story. Near to my home is a man made water channel and along each side are maintenance roads and planter areas. Every 50 metres or so are stainless steel cabinets for supplying potable water via a hose pipe to the plants when required. The cabinets are about 150 x 150 x 1,000 mm and one face is equipped with a door which provides access to the tap unit. The door also contains a 50mm hole so that the hose can be coupled to the tap and the door locked while water is flowing.
Each watering line consists of about 25 cabinets and the doors mentioned above are locked with a brass padlock.
Of late the local thieves have been smashing off the locks and stealing the brass fittings – tap, non return valve and so on. The local fuzz are on to case but they are pressed for man-power and the prospect of setting up overnight surveillance in 33C temperatures with 78% humidity and mosquitoes (I’m in Hong Kong) is not appealing.
It struck me that a PICAXE that could transmit a cabinet number which could be the answer to surveillance. If the electronics were placed on a suitable tray and the door operated a power ON when open and power OFF when closed then an identifier signal could be transmitted the moment the door opened. The small problem would be the aerial. The area in question is dead flat for considerable distances and nearby is a Government water pumping station where a receiver and ‘on duty’ surveillance fellow could rest in reasonable comfort.
I have done a search on this subject but have not had much luck in finding what I want in the forum.
Can forumites offer me advice and ideas please.
David
David
