william47316
hey there i am william and i have made some quite interesting projects using the PICAXE 08M
some of them have videos on my youtube channel http://www.youtube.com/user/williefleete
and now for a run down of one of my projects
the main project is an 8 digit LED display which controls 64 LED display segments using shift registers, 4 outputs, almost the whole code space of the PICAXE 08M, 8 bytes of 4800 baud serial input and can process 32 ASCII characters; the 10 numbers, colons, ~20 letters of the alphabet and the "bell" character, so you can just send it standard numbers and capital letters (and the bell character) to the display to control it. if you want to select a decimal point the first display can be used to select one of the other 7 displays decimal point, each digit is assigned a ram location, setting the first digit to that ram location (ASCII 81 thru 87, 80 is the first digit on the display) will turn on that digit's decimal point (coincidently Q,R,S,T,U are characters in my "ROM")
there is a video on my channel which shows this character set
plus there's a debug mode which will bypass the "character ROM" and display everything in binary.
of this i have made 3 versions, a red mini version using standard red LED displays a large green version using full size LEDs and "kiwipatch" boards IE making my own LED displays, and another using blue dot LEDs (which is quite bright) the large displays are at the moment slave units for my PICAXE clock receiving 4800 baud serial from the mini display which has the master unit in it
i will make further posts with pictures and code listings and explanations of my other devices which i have used on my 8 digit display
