$7F ???
craig008
i was looking at stroing small amounts of data and while refreshing my self on the subject i found i no longer know what type of coding this is, i know its not ascii but that is about it, just need a direction to look in
________
Medical marijuana seeds
It's a hexadecimal number, base 16.
0=0, 1=1 ... 9=9, A=10, B=11 ... F=15 when converting to decimal.
The left most digit is 16 times geater the right most digit, so ...
$7F = ( $7 * 16 ) + $F = ( 7 * 16 ) + 15 = 112 + 15 = 127 in decimal.
Hexadecimal and binary numbers are usually used instead of decimal numbers where the individual bits of a value are important ( LCD control commands and so on ) as it's easier to see which bits are set and clear without having to convert from decimal to binary. Converting hexadecimal to binary is quite easy once one gets familiar with it.
Michael 2727
Put your Windows XP Calculator on the desktop.
And run it in Scientific Mode, you can convert to
Hex, Dec, Oct and Binary - easy !
