A common mistake is to use 'K' for kilo. The kilo is designated using a 'k'.
'K' stands for degrees Kelvin. A temperature measurement!
Interesting. Didn't know about that one. Why not use 'm', as in 4m7? Haven't seen it used.
Yes I do make typos from time to time and do try and fix most that I spot even if a bit later in terms of spelling.
Virtually all resistor manufacturers (have a look at Vishay, IRC and Welwyn for example) use a capital K when using the letter "amongst the digits" more as a "code" than a prefix.
Vishay on their datasheets for example will state 4K7 = 4.7 k ohms - all very correct when we consider the 4K7 is a form of code.
likewise R is not an SI multiplier but is used along with L in the resistor industry, both as upper case in the "coded" sense of component value.
But yes, by ISO 1000, lower case "k" is correct for kilo.
When writing out values and units, in compliance with ISO 10000, we should also note that:
Unit symbols shall be printed in roman (upright) type (irrespective of the type used in the rest of the text), shall remain unaltered in the plural, shall be written without a final full stop (period) except for normal punctuation, e.g. at the end of a sentence, and shall be placed after the complete numerical value in the expression for a quantity, leaving a space between the numerical value and the unit symbol.
Unit symbols shall in general be written in lower case letters except that the first letter is written in upper case when the name of the unit is derived from a proper name.
I do try to follow this in terms of upper and lwoer case and a space between the numeric and units parts but admit I do fail to comply from time to time.
Oh and with respect to:
when using the kelvin units of temperature measurement,
1. kelvins are the increment not degrees, and
2. "kelvins" use a lower case "k" when written as the word
so we can write/say that 0 kelvin = −273.15 degrees Celsius
If we refer to the thermal scale then yes use a capital "K" for the "
Kelvin scale".
