4.1.4 ?
The full install of 4.1.4 on the Rev-Ed web site seems to actually be 4.1.2.
Both the Splash Screen and About indicate that it is 4.1.2 and the latest version mentioned in revision.txt is 4.1.2 - progedit.exe is 2527232 bytes in size.
Applying the 4.1.0 to 4.1.4 patch over the top gives a Splash Screen and About showing 4.1.4, progedit.exe becomes 2572288 bytes, and revision.txt mentions 4.1.4.
Correct, we haven't finished quality checking the full install yet. Patches can be uploaded much quicker because the installer doesn't have to go through all the installer checks.
rihoe
Suggestion - wouldn't it be much easier for customers if the patches (ZIP files) would also contain the correct folders, so that users could just unzip the patch. Now it must be manually sorted across different folders
alihawar
Yes,version 4.1.4 is available,
i had similar problem.
SOLUSION.
when installed version 4.1.2 , downlaod the patch for 4.1.4, then unzip it to C:\Program Files\Programming Editor.
thus u will get version 4.1.4.
Edited by - alihawar on 9/4/2004 7:35:27 AM
