3x3x3 led cube
ajcgkm
I decided as a first project to tackle the 3x3x3 led cube. I had a look on youtube but I think there was only one done with a picaxe all the others were pic chips. The code is fairly basic with around 13 routines. Each loop of the main program calls a random routine and displays it. I have only been learning this language for about 2 weeks so be easy on me
its available to look at on youtube here is the link
http://www.youtube.com/watch?v=1wwQ31OpC94
eclectic
Welcome to the Forum
An excellent first project.
Can you post the schematics and program,
so that others can benefit?
e
ajcgkm
the plans
yes here are plans feel free to mod if you want.
The schematic is a drawing and easier to follow so have fun and if you improve on my code let me know I can use it on mine :p
Sorry code was to long to post and I couldnt attach it either so if you want it give us your email and I will post to you. I did try to attach it but could not
eclectic
There ae sections of your code which do not pass Syntax for an 18M2.
For example
fade:
 for b8 =1 to 255 step 1 '** To speed up change to 2 to 15 **
  pwm pinsb,b8,1 '** LED 0 on first, 1 to 255 back to 1 **
  'pause 3 '** To slowdown insert pause 1 to 10 here **
 next b8
 for b8=225 to 1 step -1'** To speed up change to 2 to 15 **
  pwm pinsb,b8,1
  'pause 3 ** To slowdown insert pause 1 to 10 here **
 next b8
e
nick12ab
Entire code passes syntax check for me.
I don't understand why pinsB is used as the pin for PWM
pwm pinsb,b8,1
The code will mean that the pin used for pwm depends on the value of pinsB - remember that few pins can do PWM.
eclectic
I stand corrected.
In my earlier post, I was using a PE 5.40 computer, which gave the Syntax error.
Moving to v. 5.5 show no syntax error, and the Manual (7.8) also
shows pwm available on the 18M2.
e
ajcgkm
nick12ab that fade section of code was from some other program snippet that was kindly posted by another member on this forum. I have been using this language for 2 weeks and the manual is not very informative so I am still learning via experimenting. Why pinsB? well it worked and that was all I needed. There may be another way but until I learn some more this will have to do.
