lbenson
Here is a picaxe web server, derived from hippy's code in post #28 in the thread, Where's the Wizard? https://picaxeforum.co.uk/threads/wheres-the-wizard.31896/ and hemi's suggestion of using javascript on a remote web server to actually build the html (on a pi, in this case). Per Electronics Learner 123's request in ESP8266 BASIC, this works on a phone (as well as a PC browser). https://picaxeforum.co.uk/threads/esp8266-basic.31895/
Here's a sample page.
It's intended to illustrate turning on and of things (LEDs in this case, but could be relays) with radio buttons, and entering a numeric value. This value, for this page, is used to set a pwm level, with the pwm on or off based on a toggle setting, and ramping and fading of the pwm with a separate toggle. A series of 7 radio buttons allow 7 differently colored LEDs to be turned on or off (singly).
PCB, ESP, PWM module:
I juggled some of hippy's code. By pre-setting the wifi information on the esp including the ip address, I was able to eliminate the Station.basinc file. I set up one #DEFINE area and three subroutines in the main program, 28esp8266, to 1) initialize data for this application; 2) write the HTML code which sets javascript variables and invokes the remote javascript; 3) process the URL that is returned from the browser (e.g., L=1&P=1&R=1&N=512&X=G); and 4) provide code which is run every 10 milliseconds while the program is otherwise idling waiting for a browser entry. The subroutines are called processURL, and mainUserLoop.
Here's the .bas program with the main user-modifiable routines:
This is the b5a.js javascript file on the pi:
And the s.css file on the pi. All this does at present is set the background (which could be done without CSS), but could be used to sculpt the appearance of the output.
I made perhaps the world's worst tech youtube video, since I was trying to watch the camera and watch my phone to see where to press the buttons,, but at least it shows that the web page works on a phone, and it shows the ramping and fading of the PWMed light:
Attached are the include files, Esp8266.basinc and Server.basinc. Remove ".txt" from the attached files to get the file names you need.
' 28Esp8266
'===== Contents =====
' InternetControlledPicaxe.bas
' esp2866.basinc
' Station.basinc
' Server.basinc
'===== InternetControlledPicaxe.bas =====
#Picaxe 28X2
#No_Data
#No_Table
#terminal 19200
#com 4
#define testAPP1
; This program connects as a station to a
; specific access point and then delivers
; HTML pages to anyone who request them.
symbol cQuote=34 ' double quote
symbol ledFlag=bit16
symbol pwmFlag=bit17
symbol fadeFlag=bit18
symbol rampDirectionFlag=bit19 ' 0 is down, 1 is up
' variables through w9 (b19:b18) used
symbol wPWMDuty=w10 ' b21:b20
symbol wPWMDutyNow=w11 ' b23:b22
symbol whichLED=b24 ' LED Pin # -- B1-B7
symbol i=b25
symbol chLED=b26 ' LED character value "P","R","Y","B","G","W","C","O"
' Pink, Red, Yellow, Blue, Green, White, Chartruese, Orange
; Define access point to connect to
'#Define SSID "MySSID"
'#Define PASSWORD "MyPW"
; Define an ADC input channel if required
'#Define ADC_CHANNEL 0
; Define a LED output pin if required
'#Define LED_OUTPIN outpinB.7
'#Define LED_DIRPIN dirB.7
#Define RAMStart 56
#IFDEF testAPP1
symbol wordAdr10000=b48 ' used b48:b49:b50:b51:b52 for bintoascii destination; b53 not used
high b.0,b.1,b.2,b.3,b.4,b.5,b.6,b.7
low b.0,b.1,b.2,b.3,b.4,b.5,b.6,b.7
for b4=B.0 to B.7: high b4: pause 500: low b4: next b4: pause 500
wPWMDuty=0: wPWMDutyNow=0: pwmFlag=0: fadeFlag=0: ledFlag=1: whichLED=5: chLED="W"
bintoascii wPWMDuty,b48,b49,b50,b51,b52
if ledFlag = 1 then: high B.0: else: low B.0: endif
if whichLED > 0 then: high whichLED: endif
#ENDIF
#Include "esp2866.basinc"
' #Include "Station.basinc"
#Include "Server.basinc"
putHTML:
length= 300 ' 234 ' 437 ' 228 ' LB 200303
; Indicate we have a reply
Gosub SendReply_SendLength
; Send the actual reply
; Whether the <html><body>...</body></html>
; wrapping is required depends on the browser
; which receives the data.
; Plain text can be returned which may be
; most appropriate if another PICAXE is to
; receive the data
SerTxd( CR, LF, "Send reply - ", #length, " bytes", CR, LF )
HSerOut 0, ( "<html><head><link type=text/css rel=stylesheet href=http://192.168.1.144:20780/s.css>" )
pause 50
HSerOut 0, ( "<link rel='icon' type='image/png' href='data:image/png;base64,iVBORw0KGgo='> " )
pause 50
HSerOut 0, ( "</head><body></body>" )
pause 50
HSerOut 0, ( "<script>var arrayCurVals = [" ) ' [1,1,0,133,",cQuote,"W",cQuote,"]
pause 50
HSerOut 0, ( #ledFlag,",",#pwmFlag,",",#fadeFlag,",",#wPwmDuty,",",cQuote,chLED,cQuote )
pause 50
HSerOut 0, ( "];</script>" ) ' 87 is "W"
pause 50
HSerOut 0, ( "<script src=http://192.168.1.144:20780/b5a.js></script></html> " )
pause 50
processURL:
SerTxd( CR, LF, "processURL", CR,LF )
If Found("favicon.ico") Then
SerTxd( CR, LF, "Got favicon.ico request", CR,LF )
uptoPtr = savePtr
Gosub CloseReply
Return
End If
ptr=saveUrlPtr ' lb
for i=1 to 24: sertxd(@ptrinc): next i: ptr=saveURLPtr: sertxd(cr,lf)
'#rem
Do
select @ptr ' looking for "A"-"Z"
' e.g., L=1&P=1&R=1&N=512&X=G LED, PWM, Ramp/Fade, PWM DUTY, LED on B.1-5, B.7
case "L": ptr=ptr+2
if @ptr="1" then : high B.0: ledFlag=1 : else : low B.0: ledFlag=0 : endif ' indicator LED
case "R": ptr=ptr+2: if @ptr="1" then : fadeFlag=1 : else : fadeFlag=0 : endif ' ramp & fade PWM LED
case "P": ptr=ptr+2: if @ptr="1" then : pwmFlag=1 : else : pwmFlag=0 : endif ' pwm LED on or off
case "N": ptr=ptr+2: wPWMDuty=0
do while @ptr <> "&" and @ptr <> " "
if @ptr => "0" and @ptr <= "9" then : wPWMDuty = wPWMDuty * 10 + @ptr - "0" : endif
inc ptr
case "X": ptr=ptr+2: lookdown @ptr,(0,"R","Y","B","G","W","C","O"),whichLED ' B.1-B.7
' if whichLED = 6 then : inc whichLED : endif ' 20X2 B.6 becomes B.7
low 1,2,3,4,5,6,7: high whichLED
chLED=@ptr
sertxd("Pin B.",#whichLED," HIGH",cr,lf)
endselect
ptr = ptr + 1
Loop Until ptr => uptoPtr
if pwmFlag = 1 then
sertxd("Pwm turning on; duty=",#wPWMDuty," on pin ",#pPWM,cr,lf)
if fadeFlag = 0 then ' turn on LED, max PWM
pwmout pwmdiv16, pPWM, 249, wPWMDuty ' 500=50%, 1000=100% ' 1kHz else
wPWMDutyNow=wPWMDuty
pwmout pwmdiv16, pPWM, 249, wPWMDutyNow ' 500=50%, 1000=100% ' 1kHz else
PWMOUT pPWM, OFF
'#endrem
mainUserLoop: ' this is called every 10ms while idling
if pwmFlag = 1 and fadeFlag = 1 then
if rampDirectionFlag = 1 then ' ramp up
wPWMDutyNow = wPWMDutyNow + 10
if wPWMDutyNow > wPWMDuty then ' reverse direction
wPWMDutyNow = wPWMDutyNow min 10 - 10
rampDirectionFlag = 0
pwmduty pPWM, wPWMDutyNow
else ' fade
if wPWMDutyNow = 0 then: rampDirectionFlag = 1: endif
document.body.innerHTML = "" +
'<html><head><title> LED Control</title></head>' +
'<body><form name = input method = get>' +
' <font color=blue><font size=5>Picaxe Web Server</font><br><br>' +
' <font color=black>' +
' <table border="1">' +
' <tr><td><input type="radio" id="A" name="L" value="1">LED ON</td>' +
' <td><input type="radio" id="B1" name="L" value="0">LED OFF</td></tr>' +
' <tr><td><input type="radio" id="C" name="P" value="1">PWM ON </td>' +
' <td><input type="radio" id="D" name="P" value="0">PWM OFF</td></tr>' +
' <tr><td><input type="radio" id="E" name="R" value="1">Ramp/Fade ON </td>' +
' <td><input type="radio" id="F" name="R" value="0">Ramp/Fade ' +
' OFF</td></tr></table>' +
' <p>PWM Duty Cycle:</p>' +
' <input type="text" id="G" name="N"><br><br>' +
' <p>Select LED:</p>' +
' <input type="radio" id="R" name="X" value="R">Red<br>' +
' <input type="radio" id="Y" name="X" value="Y">Yellow<br>' +
' <input type="radio" id="B" name="X" value="B">Blue<br>' +
' <input type="radio" id="G" name="X" value="G">Green<br>' +
' <input type="radio" id="W" name="X" value="W">White<br>' +
' <input type="radio" id="O" name="X" value="O">Orange<br>' +
' <br><button type=submit>Submit</button>' +
'</form></body></html> '
var ledStatus = arrayCurVals[0]; // this will be "0"
var pwmStatus = arrayCurVals[1]; //this will be "1"
var pwmRamp = arrayCurVals[2]; //this will be "1"
var pwmDuty = arrayCurVals[3]; //this will be, e.g., "321"
var ledColor = arrayCurVals[4]; // this will be "W"
if (ledStatus == 1) { document.getElementById("A").setAttribute("checked", true); }
else { document.getElementById("B1").setAttribute("checked", true); }
if (pwmStatus == 1) { document.getElementById("C").setAttribute("checked", true); }
else { document.getElementById("D").setAttribute("checked", true); }
if (pwmRamp == 1) { document.getElementById("E").setAttribute("checked", true); }
else { document.getElementById("F").setAttribute("checked", true); }
document.getElementById("G").value=pwmDuty
document.getElementById(ledColor).setAttribute("checked", true);
body {
background-color: #d0d0d0;
h1 {
color: #fff;
font-family: Arial, Helvetica, sans-serif;
